I’m trying to edit my footer. I have put in some text but its ended up with a white border round it which I don’t want. puravidacoaching.co.uk for you to see it. How do I remove that. I also want to change the colour to blue and the text all to white, is that possible? Thanks
Hello. Unfortunately, to make these changes you’d need to selectCustomize > Advanced > Advanced JS & CSS. There you can add custom CSS. You’ll need to go to the footer of your website and do an Inspect Element on the text in your footer to see what classes you’ll need to edit. You can see our documentation and Google Developer guide for more info on this.
Author
The topic ‘Help with footer editing’ is closed to new replies.
