- November 23, 2018 at 9:50 am #29365
BT Boldgrid
GuestI am getting the following error on dashboard:
Your theme (Hifidel) contains outdated copies of some WooCommerce template files. These files may need updating to ensure they are compatible with the current version of WooCommerce. Suggestions to fix this:
- Update your theme to the latest version. If no update is available contact your theme author asking about compatibility with the current WooCommerce version.
- If you copied over a template file to change something, then you will need to copy the new version of the template and apply your changes again.
Template Details:
boldgrid-hifidel/woocommerce/archive-product.php,
boldgrid-hifidel/woocommerce/cart/cart-empty.php
version 3.1.0 is out of date. The core version is 3.5.0,boldgrid-hifidel/woocommerce/cart/cart.php
version 3.4.0 is out of date. The core version is 3.5.0,
boldgrid-hifidel/woocommerce/cart/proceed-to-checkout-button.php,boldgrid-hifidel/woocommerce/checkout/cart-errors.php
version 2.4.0 is out of date. The core version is 3.5.0,
boldgrid-hifidel/woocommerce/checkout/form-billing.php,boldgrid-hifidel/woocommerce/checkout/form-coupon.php
version 3.4.0 is out of date. The core version is 3.4.4,boldgrid-hifidel/woocommerce/checkout/payment-method.php
version 2.3.0 is out of date. The core version is 3.5.0,
boldgrid-hifidel/woocommerce/checkout/payment.php,
boldgrid-hifidel/woocommerce/global/breadcrumb.php,
boldgrid-hifidel/woocommerce/global/form-login.php,
boldgrid-hifidel/woocommerce/global/quantity-input.php,
boldgrid-hifidel/woocommerce/loop/no-products-found.php,
boldgrid-hifidel/woocommerce/loop/orderby.php,
boldgrid-hifidel/woocommerce/loop/pagination.php,
boldgrid-hifidel/woocommerce/loop/price.php,
boldgrid-hifidel/woocommerce/myaccount/downloads.php,boldgrid-hifidel/woocommerce/myaccount/form-edit-account.php
version 3.4.0 is out of date. The core version is 3.5.0,boldgrid-hifidel/woocommerce/myaccount/form-login.php
boldgrid-hifidel/woocommerce/myaccount/form-lost-password.php,boldgrid-hifidel/woocommerce/myaccount/form-reset-password.php
boldgrid-hifidel/woocommerce/myaccount/my-orders.php,
boldgrid-hifidel/woocommerce/myaccount/navigation.php,
boldgrid-hifidel/woocommerce/myaccount/orders.php,boldgrid-hifidel/woocommerce/notices/error.php
version 3.3.0 is out of date. The core version is 3.5.0,boldgrid-hifidel/woocommerce/notices/notice.php
version 1.6.4 is out of date. The core version is 3.5.0,boldgrid-hifidel/woocommerce/notices/success.php
boldgrid-hifidel/woocommerce/product-searchform.php,
boldgrid-hifidel/woocommerce/single-product/add-to-cart/external.php,
boldgrid-hifidel/woocommerce/single-product/add-to-cart/grouped.php,
boldgrid-hifidel/woocommerce/single-product/add-to-cart/simple.php,boldgrid-hifidel/woocommerce/single-product/add-to-cart/variable.php
version 3.4.0 is out of date. The core version is 3.4.1,
boldgrid-hifidel/woocommerce/single-product/add-to-cart/variation-add-to-cart-button.php,
boldgrid-hifidel/woocommerce/single-product/price.php,
boldgrid-hifidel/woocommerce/single-product/tabs/tabs.php,boldgrid-hifidel/woocommerce/single-product-reviews.php
version 3.2.0 is out of date. The core version is 3.5.0,
boldgrid-hifidel/woocommerce/single-product.phpNovember 23, 2018 at 11:15 am #29366BoldGrid Contributor
GuestThanks for contacting us. We’ve been working on this but have no estimated time to completion. I apologize for any inconvenience.
November 23, 2018 at 12:13 pm #29367BT Boldgrid
GuestIs there a theme that is currently compatible?
November 23, 2018 at 1:32 pm #29368BT Boldgrid
GuestI also need to know how long something like this is going to take. I will request a refund with inmotion hosting. The whole idea around my site was a I was going to be able to start using Boldgrid +WooCommerce. I am not trying to be a jerk. However, moving forward I would like to know as this kinda set the bar for the site moving forward. It determines if I need to go for a different solution all together like Wix or Shopify. The advantages I can see are that the sites and backend software are all maintained by those companies. Where Boldgrid+WooCommerce have different development times frames and teams. Meaning this could create problems in the future for the site.
November 26, 2018 at 3:11 pm #29369carlosd
GuestThe Hifidel theme appears to be compatible. When I loaded up the theme, I do see that some of the templates are outdated, however, the theme still shows as compatible.
November 26, 2018 at 3:15 pm #29370carlosd
GuestUnfortunately, I am not able to provide a timeframe for the theme to be updated. You can, in the meantime, follow the WooCommerce guide to manually update the template files. Otherwise, just be sure to keep your theme updated to ensure you have the latest template files, as soon as they are available.
- The topic ‘Hifidel not compatible with Woocommerce – Is there a fix?’ is closed to new replies.
