  • #29598
    entrepreneurgirl
    Not using BoldGrid themes, How do I stage and test my EXISTING wordpress site?
    #29599
    BoldGrid Contributor
    Hello and thanks for contacting us. I recommend you ensure you have the BoldGrid Staging plugin activated and simply disable BoldGrid Inspirations from your Plugins section. The Appearance tab will then show in your dashboard. Also, ensure all plugins and themes are up-to-date and remove themes you’re sure you won’t be using – i.e. annual WordPress themes.
    #29600
    entrepreneurgirl
    Thank you! It worked like a charm!
  • The topic ‘Not using BoldGrid themes, How do I stage and test my EXISTING wordpress site?’ is closed to new replies.
