Viewing 8 posts - 1 through 8 (of 8 total)
  • #30028
    sbush
    I built a slider – but I see it only allows for three photos, and very simple transitions. In WordPress I know there are more options than that. Is there a way I can add more photos than one show at once in Bold Grid? More creative transitions?
    Thanks.
    #30029
    johnpaulb
    Hello sbush,
    Thank you for contacting us about using Sliders in BoldGrid. Yes, you can use multiple sliders on the same page in BoldGird and WordPress.
    Thank you,
    John-Paul
    #30030
    sbush
    Thanks for responding. My issue is I can only put in three photos in a slider (I see I could put many sliders in – they would be in different rows, it seems)- but I want to add photos to an existing slider. I’d also like to use different types of transitions. Maybe I need a plug in ?
    #30031
    johnpaulb
    Yes, if the slider you built is not meeting your needs, a plugin is a good option.
    #30032
    sbush
    Is there one you recommend?
    #30033
    carlosd
    We recommend reviewing the wordpress.org plugins available. You’ll want to keep in mind the features you’re looking for, the last time the plugin was updated, as well as the version of WordPress it’s been tested with. It’s much more of a pleasant experience if the plugin’s developer updates frequently and tests with the latest version of WordPress.
    Carlos D.
    #30034
    sbush
    I installed the “highest rated” plug in last night, Soliloquay (sp?) and went through the steps (watched a video – sure I did it right) and it Did not work! ugh. Also, this may seem like a dumb question, but what’s it called when there’s a transparent block that the words or photo seem to move behind as the user scrolls down? That was in my original layout, but I evidently deleted it. I am hoping it’s an option in the blocks, but unclear. It would be kind of neat it they labeled some of these things in the inspirations and told you where to find it/what settings to use. My needs are probably more basic than some of yours – but if they’re trying to make it simple… wth…
    #30035
    BoldGrid Contributor
    It sounds like you’re talking about the Z Index. If you want default settings of something, you could always backup the website, remove the plugin/theme, and reinstall it. Also, you could also contact the plugin developer regarding your issue with their product.
  • The topic ‘Help with Sliders’ is closed to new replies.
