- December 14, 2018 at 3:56 am #21976
MemberEverything was working normally until today I tried editing my pages with boldgrid and I cannot add any blocks from my block library. Furthermore the typical ‘drag and drop’ edit style isn’t working either. Overall things are not working the way it is meant to.
December 19, 2018 at 5:17 pm #21977Arnel C
MemberHello,
Apologies for the problems with the Add block function from the block library as well as the drag-and-drop issues. We would need more information in order to investigate the issue. Can you please provide your domain name and version information for the plugins and WordPress? Providing access may also be necessary for us to be able to investigate the issue in more depth. rid plugins are up-to-date and WordPress is updated. Make sure that all of your BoldGrid plugins are up-to-date and WordPress is updated. Remember also that BoldGrid is a series of plugins for WordPress. If you have loaded another theme editor or plugin, it is possible that a conflict may exist with that plugin. Disable your plugins (except the BoldGrid ones) one-by-one to see identify any plugin issues.
If you have any further questions or comments, please let us know.
Kindest regards,
Arnel C.
August 10, 2020 at 2:09 pm #25756Gerald
GuestI had same issue with new BG update 1.3 here I disabled YOAST SEO plugin and that was causing the conflict with BG…all fixed now as long as I keep YOAST SEO disabled.
August 10, 2020 at 2:44 pm #25769Jesse Owens
KeymasterHi Gerald-
It sounds like you’re having the same issue mentioned in this thread and we’ve filled out a bug report for our developers.For now, I’d recommend activating Yoast and deactivating BoldGrid Easy SEO until we can release a fix for this issue.
August 11, 2020 at 11:45 am #25813Jesse Owens
KeymasterHi Gerald-
I wanted to let you know that BoldGrid Easy SEO version 1.6.7 has been released, and fixes this conflict with Yoast. You can upgrade the plugin now and use both Yoast and BoldGrid Easy SEO together. - AuthorPosts
- The topic ‘Add block is not working and normal “drag and drop” functions of bold grid editor not working’ is closed to new replies.
