  • #153724
    Alexia Surtel
    Bonjour,
    J’ai le message d’erreur suivant :
    The following memcached servers are not responding or not running:
    Cache de base de données : 127.0.0.1:11211.
    Cache objet : 127.0.0.1:11211.
    This message will automatically disappear once the issue is resolved.
    Je ne sais pas comment résoudre l’anomalie, pourriez-vous m’aider ?
    Bonne journée à vous
    #153751
    Hello Alexia,
    This is related to the Memcached installation on your server, to be able to use it in the W3 Total Cache
    Check the service at the CLI/SSH: memcached-tool 127.0.0.1:11211 display and memcached-tool 127.0.0.1:11211 stats.
    telnet 127.0.0.1 11211
    should communicate with memcache and respond to status commands etc
    Look if the service is running: ps afux | grep memc
    restart the service if needed (as root/sudo): service memcached restart.
    Let me know if this helps!
  • The topic ‘Adress IP qui ne fonctionne pas’ is closed to new replies.
