- March 3, 2022 at 3:45 pm #48068Cheryl Smithem GuestI’m working on a single page site with anchor links / IDs to various sections. We have done this in a few other sites, using the advanced controls to set an ID for that element. However, that advanced control seems to have vanished. I tried looking for it on columns, rows, and blocks, and it is not appearing. https://www.boldgrid.com/support/page-builder/advanced-controls/ I logged in to other sites we have used it on and while the menus still function, the Advanced Menu does not show the missing item. Custom CSS – Enter Custom Classes or a CSS ID for the element Do you have any insights as to what is happening? I’ve tried both Chrome and Firefox and not seeing it in either…though for a moment this morning I DID see it when I went to a block and so went to the one where I want to set an ID and it no longer was visible. Went back to the one where I had just 3 min before seen it and it was gone. I think there may be a javascript error? When inspecting the page, the CSS shows that the Menu item is in the code, however, it is not visible. I’ve placed two screen captures illustrating this in a dropbox folder https://www.dropbox.com/sh/5nqfeqdb2tyel11/AABGiWfHawHwpnakxWwOoMsTa?dl=0 March 3, 2022 at 3:51 pm #48077Brandon C ParticipantHi Cheryl, Thank you for reaching out and thanks for using BoldGrid Post and Page Builder for WordPress I’m sorry to hear you’re are experiencing this issue and I want you to know that this is a bug that has been identified and set to be corrected in the upcoming “Post and Page Builder 1.17.1” release. If you do not wish to wait for the patch release there is a workaround. You can download and install WP Rollback to rollback to a previous version of post and page builder to restore functionality that way. I hope this helps. Please reach back out if you have any other questions for us.
- The topic ‘Advanced Control Custom CSS Menu Element is not appearing’ is closed to new replies.
