  • #43669
    Kanchan
    My website speed is slow on phone due to render blocking css or js, so we had upgrade you plugin to resolved render blocking issue, but after adding render blocking css file list its create inline css and increase load time can you help me so that i can enhance speed on mobile.
    #43709
    The “eliminate render-blocking CSS by moving it to HTTP body” option only works for the minified CSS files. As I see some files are not being minified.
    You also have some external files that cannot be minified by the W3 Total Cache.
    Are you using any AMP plugin by any chance and what theme are you using for your website?
  • The topic ‘After enable render blocking for css file, speed not increasing’ is closed to new replies.
