  • #154693
    Brittany Crawford
    Hi there! I am having trouble removing the “is proudly powered by WordPress” text from my website. It does not seem to be a part of the footer settings, therefore all of the suggestions I have seen online to get it to removed aren’t working. Can you help? Thanks! http://www.thethreedrivers.com
    #154698
    Elana
    Hello Brittany,
    If you have a Crio Pro Subscription, you can remove the BoldGrid and Special Thanks attribution links using the checkboxes in the Customize > Design > Footer > Layout menu:
    Or if you wanted to check out the guide on how to remove Special Thanks and Attribution Links.
    Elana D.
  • The topic ‘Attribution info will not go away’ is closed to new replies.
