- December 11, 2020 at 2:06 pm #32132
Emily Gale
GuestI’ve been using the block library to make templates for posts that will be easy to grab and fill in when making a new post. I have also been saving certain blocks from pages that I want to use again into the block library.
However, when i go to add blocks from the block library, or even try to find the block in the used blocks category, only 1-4 blocks load and they are not usually the ones I am looking for. This is incredibly frustrating to have happening constantly and is making me reconsider if boldgrid will be the right tool for being able to post as needed for my business. Does the plugin just have loading issues that cannot be resolved? I have seen other people posting about this problem so it seems to be ongoing..
December 11, 2020 at 3:44 pm #32153Jesse Owens
KeymasterHi Emily-
Generally speaking, this type of issue is a temporary connectivity issue between your website and the BoldGrid asset server, and should resolve on its own.
If this is still happening, please reach out to our premium support team so we can take a closer look for you. (As an InMotion Hosting customer, you have a premium subscription included with your hosting)
- The topic ‘block library + used blocks don’t load’ is closed to new replies.
