Todd J
GuestI would like to add a page where products I recommend are displayed. What block is best suited to this task?
Elana
KeymasterHello Todd,
Thank you for reaching out to our support team.
If you are using WooCommerce you can take advantage of the featured products option. If you add the block Product List to your form you will see a dropdown under show that will show featured products only.
Then in your products -> product you can quick edit a product and select the checkmark for featured. Then it will show in the featured product list on the page.
Elana.- AuthorPosts
