I have been having the same problem and have tried various recommendations from you to fix but still boldgrid editor does not load when I’ve gone back in to edit a post or a page!
Thank you for your question about your BoldGrid editor not loading. Which editor exactly are you referring to? What steps are you taking that consistently produce this issue? What does your PHP error or other log files say when you have this error?
Gratefully,
Casey B.
Author
The topic ‘BoldGrid Editor Does Not Load’ is closed to new replies.
