- January 7, 2021 at 1:59 pm #32787
Nick
GuestHello, when I go to edit a page on my website with the Boldgrid page editor, the visual tab is completely blank. I can select the text tab and see the page code, but I cannot edit the blocks visually in the visual tab at all, nothing shows up. Any help would be appreciated!
January 7, 2021 at 2:07 pm #32794Jesse Owens
KeymasterHi Nick-
It sounds like you’re getting some kind of JavaScript error that’s preventing the BoldGrid Post and Page Builder from loading. Most often, this is due to a plugin conflict.
One thing that can help us determine what might be the cause is to check your browser’s error console when you try to load the editor. Here’s a short video on how to use your error console.
Another possibility is that some plugins might be out-of-date. WordPress has released a few updates in the last couple of months that changed the core jQuery JavaScript library, and many plugin authors (ourselves included) needed to update our plugins to work with the new version. Make sure that all your plugins and your theme are up-to-date.
Another thing you can try is to deactivate plugins one-by-one to see if the issue resolves. Start with any plugins that add functionality to the editor screen, because they’ll be most likely to interfere with the editor.
January 7, 2021 at 4:49 pm #32808Nick Ashcroft
GuestFirstly, thank you so much for such a fast reply!
I found this error message.
I had already updated all the plugin and theme so I don’t think it’s that….?v=2.0:6 WebSocket connection to ‘wss://public-api.wordpress.com/pinghub/wpcom/me/newest-note-data’ failed: Error during WebSocket handshake: Unexpected response code: 403
Thanks again.
NickJanuary 7, 2021 at 6:37 pm #32815Nick Ashcroft
GuestHave tracked down a plug-in that appeared to be creating the issue…
A WP plugin call Helpie FAQ – thanks for your help.January 7, 2021 at 6:39 pm #32817Jesse Owens
KeymasterHi Nick-
Thanks for that update! I’m glad to hear you got it fixed. We’ll do some testing on our end and see if we can fix it in Post and Page Builder. I’ll update you here if we can determine the cause.
- The topic ‘Boldgrid Visual Tab Problem’ is closed to new replies.
