The Boldpress theme is not part of BoldGrid, If you are having issues with it i would recommend reaching out to their developers to see if they can give you any information on that, It looks like that theme is on http://dinothemes.com/. That theme also looks to only be supported for WordPress 3.2 which is about 6 years out of date, You may want to try looking for a different theme.
Best Regards,
Kyle M.
