- September 25, 2020 at 12:12 pm #27515
Peeyush Gupta
GuestI am using your W3 Total Cache plugin with Cloudflare extension.
I have these issues
one is cdn path is not working
leverage browser cache result is not good in GTMetrix website. plz refer url.
Opcode Cache is not enable, even i config option in cpanel, apc, apcu and ocode.September 25, 2020 at 12:56 pm #27529Jesse Owens
KeymasterHello Peeyush-
I do see that GTMetrix is showing that your image assets have a browser cache time-to-live (TTL) of 4 hours, and JavaScript files are showing 2 days.
By default, W3 Total Cache sets a TTL of 1 year (31,536,000 seconds). You can check on this in your Performance > Browser Cache menu. However, it is possible for CloudFlare to override your TTL values. Here’s more information on how to check on your CloudFlare TTL settings.
Regarding your Opcode Cache, are you able to publish a phpinfo.php file on your site so we can double-check the settings?
When you say your CDN Path is not working, are you getting any error messages, or can you describe what steps you’re taking when you see the issue?
- The topic ‘Browser Cache Score Low with W3 Total Cache and CloudFlare’ is closed to new replies.
