  • #37848
    Prajakta
    I just have simple question about Cache group setting. If I have multisite network installed, and I wanted to do “Cache group” setting for each site separately, then, I should have to go with pro version of plugin? If yes then $99 plan will work for all subsites? Please suggest.
    #37864
    Hello Prajakta,
    Thank you for reaching out.
    As I’ve already stated in the email I am currently testing the behavior.
    No, you do not need the Pro version of the plugin to use Cache Groups.
    I’ll get back to you as soon as I can replicate this on the multisite.
    Sherlyn
    I have the same problem, it would be great to also know the answer for this.
  • The topic ‘Cache group setting for multisite network’ is closed to new replies.
