  • #22170
    I’ve searched everywhere, but I was unable to locate help with this specific question.  How do I change the background color of the “below site title widget”?  I’m only using text, but the white box surrounding my text is what I would like to remove and make it clear/transparent.  Please help!  Thanks!
    #22173
    If you’re unable to edit it from within Customize > Site Title & Logo, you may need to apply custom CSS within the Advanced > Custom JS & CSS section.
    #22172
    Hi JT, thanks for your response.  Can you tell me what that CSS code would be?  Thanks
    #22171
    JohnPaul B
    Member
    We are happy to help guide you with using BoldGrid, but coding solutions will require testing and troubleshooting since sites can differ. We do have a helpful guide on how to Use Google Chrome Developer Tools to Customize CSS in BoldGrid.
    Thank you,
    John-Paul
  • The topic ‘Changing Background White Color Below Site Title Widget’ is closed to new replies.
