  • #131087
    Shubha Chakravarthy
    Hi
    I need to change the global color palette on a commercial theme (Voice from Mess)…how do I fix this? Please help!
    #131107
    Hi Shubha,
    Thank you for reaching out with your BoldGrid Post and Page Builder questions!
    The settings in your theme might be limited to certain areas of your website and may not affect content inside the BoldGrid Post and Page Builder blocks. Please see if you can follow this guide to get your global color palettes functioning properly with Post and Page Builder.
    Your Voice theme is considered a third-party integration to Post and Page Builder, which means modifying elements globally may be tricky.  Theme settings often control the overall look of the site but might not override the styles set within page builders.
    While Post and Page Builder will work with most non-BoldGrid themes, the default styling provided by the builder might not exactly match the style of your third-party theme so you may need to make additional adjustments to ensure consistency across your site.
    I hope this helps!  Please let us know if we can assist you further with this.
    #131118
    Shubha Chakravarthy
    I tried this but it went right back to the blue when I updated the page. I am using Meks Voice theme….any further suggestions please?
    Hi Shubha,
    Sorry to hear that didn’t work for you.  Another suggestion is a more advanced approach.  It would involve using custom CSS to ensure your global elements.  This could be problematic in the page editor itself because some of your changes may not be reflected there even though they’re visible on the live website.
    This problem is your “Voice” theme is a third party theme and global elements like font and color are almost always controlled by the theme. Being that Voice has no relationship with Post and Page Builder they have no obligation to stay current with our latest updates and functional requirements and Post and Page builder will only address fonts created in the plugin itself.
    If you would like to preview a theme where this is possible you should consider Crio Pro WordPress theme! Crio is our flagship WordPress theme and is 100% compatible with Post and Page Builder. With this combination you would have global font and color control right out of the box, as well as, more than 400 other premium features.
    I hope this helps. Please let us know if there’s anything else that we can answer for you.
  • The topic ‘Changing color palette of third party theme and Post and Page Builder’ is closed to new replies.
