- March 17, 2025 at 10:35 am #154840
Harleen Sodhi
GuestWhen adding more content to a page, I cloned the module couple of times and then change the content on additional modules to reflect additional changes. But after publishing I see content of the page displaying multiple times. When I check the same page in edit mode, it shows everything is correct and displayed once as intended. I even checked the code, and nothing is repeated.
I am not a pro and I just learned very little about WordPress, and try to maintain the site. Can anyone help?
How should I get rid of the content that is being displayed multiple times on the page on the website?
Thank you
HarleenMarch 17, 2025 at 10:37 am #155221Elana
KeymasterHello Harleen,
Thanks for reaching out with your BoldGrid Post and Page Builder question.
Sorry to hear you’re having trouble cloning your block elements but I think we should be able to help you out. The elements on your live website should appear exactly the way they appear in the page editor.
I think it may just be an issue of caching. Elements are often cached into websites for performance purposes but it can become a bit problematic when your editing a live site. To correct this you should clear any cache associated with your website (including any browser cache and/or server side cache) in order to rebuild the database.
Let us know if that works or if you continue to have issues. We are happy to help.
Elana. - AuthorPosts
- The topic ‘Clone module issue’ is closed to new replies.
