- November 29, 2022 at 6:56 am #71082
Mus
GuestHi,
The button to authorize Cloudflare does not work within the plugin. I can not use my credentials to log in. I have tried Safari, Chrome, IE nothing works. I turned off adblockers, tried other devices and it still does not work.
How can I solve this problem?
Thanks in advance!
November 29, 2022 at 6:58 am #71097Marko Vasiljevic
KeymasterHello,
Can you please try to change the default WP language to English in your WP Dashboard so that W3 Total Cache can use default English and try to Authorize the Cloudflare after these steps?
Let me know if this helps!Thanks!
November 29, 2022 at 9:57 am #71099Mus
GuestWow, never thought it could be for something like this. Thanks for helping out!
November 29, 2022 at 10:02 am #71126Marko Vasiljevic
KeymasterHello,
THank you for yoru feedback.
Yes, this can be an issue with some translations. We are working on improving this of course in future releases.
Glad to know the problem is resolved.Thanks!
- The topic ‘Cloudflare Extension Button does not work’ is closed to new replies.
