  • #88015
    Javier Trevizo
    I am unable to move the columns together in the same row. When I try to adjust the size of the column the entire thing disappears. Currently I can edit the class to match the other columns, but I am unable to move it to adjust the size.
    For example I wanted to have 4 columns that are the same size. They would have an image and maybe some text. When I create new columns they are half the size of the previous column and keep getting smaller. I am unable to size the columns to all be the same size in the same row using the move feature.
    #88099
    Hi Javier,
    Thanks for reaching out with your BoldGrid Post and Page Builder questions!
    In order to adjust your column sizes you’ll need to use the Advanced Controls provided by Post and Page Builder. If you hover over any one of your columns a “blue” hamburger tab will appear. Click the hamburger then scroll down and select “Advanced Controls” and from this section you’ll have the ability to resize the column or change it’s shape.
    If you want to have absolute control over the column and you’re comfortable using custom CSS then you can add a custom class or ID to each column and select it in the CSS/JS editor section of the WordPress Customizer to make your changes.
    I hope this helps! Please let us know if you have any other questions for us.
  • The topic ‘Columns Not Moving Correctly in Post and Page Builder’ is closed to new replies.
