  • #36963
    Marge
    Do you have any information on the compatibility with W3 TC and aMember Pro? Siteground Optimizer is not working with it.
    thanks in advance!
    #36979
    Hello Marge,
    Thank you for reaching out.
    There are no reported compatibility issues so far with aMember Pro plugin and W3 Total Cache.
    Since this plugin is managing logged in users, make sure that if you are using Page Caching that the option “Don’t cache pages for logged in users” is enabled, and disable the set expires header and cache-control header in Performance>Browser Cache>HTML&XML section of the plugin. Make sure to save all settings and purge the cache.
  • The topic ‘Compatibility with aMember Pro’ is closed to new replies.
