- May 6, 2017 at 10:24 am #24330
MemberWhen I initially set up my website I was able to see and edit my contact info (email, telephone, address) that shows at the bottom of the page directly above the “Special Thanks” link. I could have sworn there were checkboxes that allowed me to pick what I want to show. I’m trying to find it in the BoldGrid customize area so that I can put it back, but I cannot find it. I thought it was in the Advanced section. If it is, I’m not seeing it. Not sure what I did to make it disappear. Can you assist?
May 8, 2017 at 9:23 am #24331admin
MemberHello,
Thank you for your question on footer contact information. That information is not in the updated theme versions. The contact information is specifically on the Contact page and no longer in the footer.
There are checkboxes to remove the different attributions in the footer area. That is located in the Advanced >> Footer Settings area.
You can also add your contact information as HTML in the custom HTML area for the footer if you wish. But the default information is now only in the Contact page in the newer versions.
Kindest Regards,
Scott M
- The topic ‘Contact info is not showing in footer’ is closed to new replies.
