  • #74469
    Scott Montes
    Hello, I toggled the Settings>Readings homepage from Static to Latest Posts. After toggling back, my design does not load as created in Pages>Edit, instead it shows a blank as shown in Appearance>Customize. I have cleared the caches in WP and in the browser. Where is the conflict?
    Hi Scott,
    Thanks so much for reaching out with your Crio Pro WordPress theme!
    It looks like the home page you’ve selected does not have any content on it. You’ll need to either modify this page or go back into the Homepage section of your Crio customizer and select a new home page from there.
    I hope this helps.
  • The topic ‘Crio design not loading after changing homepage settings’ is closed to new replies.
