- July 27, 2020 at 4:19 pm #25407
Stephen Shewey
GuestEditing the Crio Theme in Inspirations, but will not publish after making changes.
July 27, 2020 at 5:33 pm #25412Jesse Owens
KeymasterHello Stephen-
I’m sorry to hear about the error while you’re customizing your site. I checked out the website link you sent privately, but it’s in maintenance mode so I couldn’t see very much information.
One thing I could see is that you’re using W3 Total Cache to speed up your site. It’s possible you may be seeing a cached version of your page after you publish, so be sure to clear your cache in Performance > Purge All Caches.
Beyond that, it’s tough to speculate without some more information. If you can, it’d help us out a lot if you can check your browser console for any errors you see while you’re publishing. Here’s a video I made to walk you through that, it’s a lot easier than it sounds!
July 27, 2020 at 5:37 pm #25408Stephen Shewey
GuestEven though I have checked no sidebar, it still appears on all my pages.
July 28, 2020 at 11:52 am #25418Jesse Owens
There are a couple of different options for sidebars- you can adjust them for Pages and posts separately.Make sure that you’re in Customize > Design > Pages > Sidebar and not in the Blog > Posts section.
Did you get a chance to try out the steps from the last response above?
- The topic ‘Crio will not publish’ is closed to new replies.
