- September 23, 2021 at 2:12 pm #43017
bosslady
GuestHow can I decrease the width of the lefthand menu bar (using Crio)? (The main menu currently takes up almost a third of the screen: I’d like it to cover much less.)
September 23, 2021 at 2:20 pm #43035Joseph W
KeymasterThank you for contacting us!
One of the best features of our Crio WordPress theme is the ability to create a highly customized header for your website.
The preset header layouts are a great way to quickly put together a header design, but if you need a little more control then the Custom Header Layout option might be just the tool you are looking for!
When building your Custom Layout be sure to select the Left option in the Header Position settings to keep the same left side header design you currently have. You will then see a slider at the bottom of those controls that allows you to adjust the width of the side header so it doesn’t take up as much space on your page.
Please let us know if you have any other questions for us!
- The topic ‘decrease menu width for left side header’ is closed to new replies.
