  • #47680
    JS
    Hello.
    Thank you for a great plugin.
    I am setting up a new CDN with Amazon CloudFront which I have done before on many different sites.
    However, now on the new site I am seeing this error when trying to connect to the CDN:
    Error: Distribution for origin “xxxxxxx.s3.amazonaws.com” not found
    What could be the reasons for this?
    As far as I can tell everything is configured correctly.
    Thank you so much!
    JS
    #47701
    Can you please try to create a distribution within W3 Total Cache instead of AWS? Most likely the permissions set on the AWS console are not set to public.
  • The topic ‘Distribution for origin not found’ is closed to new replies.
