- March 1, 2021 at 3:13 pm #34410
Barry
GuestHello
I am using Crio as suggested by Boldgrid. I am still looking for ways to change the theme page features. I may be interested in a paid feature to make editing accessible. For example I cannot change the font size or padding for the widget with Sermon videos / Facebook Page.
Also I do not want the menu to collapse after the menu link is selected (Menus under About US). So far I can change what I need to on individual pages.
Do I need Crio premium or boldgrid premium? I would like to limit what I must purchase as this if for a church website so once set it will not change much.
Thanks BarryMarch 1, 2021 at 7:50 pm #34436Jesse Owens
KeymasterHi Barry-
Thanks for reaching out, it looks like you’ve made a lot of progress on your website!
First, since you’re using one of our Platinum WordPress Hosting partners, DreamHost, Crio Pro is already included in your hosting subscription. If you don’t have it yet, download and install the Crio Pro extension plugin.
Since you’re only using the Text Widget to show links, you might consider using Custom Link menu items, rather than a widget, to show these. That would make them consistent with the font and padding on the rest of your menu.
That’s a pretty unique request! We haven’t built controls for this behavior yet, but I’ll be adding it to the feedback for the developers. Here’s how you can accomplish that right now.
Navigate to Customize > CSS/JS Editor and paste these two lines into your Custom JS Code:
jQuery('li.current-menu-item').parent().css('display', 'block'); jQuery('li.current-menu-parent > a').addClass('highlighted');Make sure that if the JS Code editor adds the two slashes (
//) to your first pasted line, you delete those.March 3, 2021 at 2:03 pm #34499Barry
GuestHello Jesse
Thank you for the help the menu JS worked. I tried the menu Custom Link before but can not get text after the icon. I put the Custom Link back in the menu, but my users are older and need text to let them know what the ICON means.
Thank you for informing me about CRIO PRo.
Best Regards, Barry
March 3, 2021 at 4:22 pm #34527Jesse Owens
KeymasterHi Barry-
Try adding the following to your JavaScript:
jQuery('li.menu-item > a > span.sr-only').removeClass('sr-only'); jQuery('li.menu-item > a > i').remove();Also, make sure that your ‘>’ characters are actually carets, not >’s.
March 3, 2021 at 6:54 pm #34539Barry
GuestHello works perfect. Thanks.
- The topic ‘Do I need Crio Pro to Change Header Widgets and Menus?’ is closed to new replies.
