  • #47103
    Max
    Hello – Does BG have a plugin/capability that would display contents in grid view, allowing pagination and expansion if readers decide to explore more?
    I am currently using contentview plugin (https://www.contentviewspro.com/) for this purpose and would like to know if BG has similar functionality. Thank you.
    #47125
    Hi Max,
    Thanks for reaching out with your question about BoldGrid Post and Page Builder for WordPress!
    While this functionality is not native to Post and Page builder you should be able to use your Contentview plugin to incorporate it into any one of your pages.
    Is there a particular reason you’re looking to switch from your current plugin to build this functionality? You may be able to build it using a Grid format on a blog post archive but that would be a little more complex. In this scenario you’d actually need to create a custom-archive.php type file in order to accomplish your task.
    I hope this helps. We look forward to hearing from you if you have further questions!
  • The topic ‘Does BoldGrid Post and Page Builder have grid view capabilities?’ is closed to new replies.
