  • #156740 Reply
    Jon Seymour
    Hi, We’re looking to use your plugin and wanted to know if it works with the multi domain setup on WPML. As our languages are broken up into domain names .com, .us, .es etc.
    Also, does it work with cloudflare?
    #156805 Reply
    Hello Jon
    Thank you for reaching out, and I am happy to help!
    The W3 Total Cache works with the WPML. We have a WPML extension in the plugin that can be activated if WPML is detected and you have a Pro license.
    W3 Total Cacha also works great with Cloudflare and we do also have a Clouflare extension, so please check the article on how to configure Cloudflare with the W3 Total Cache
    Let me know if you have any other questions
Reply To: Does It Work with WPML Multi Domains
Your information:
