  • #24551
    I recently installed Popup Maker in my BoldGrid plugin arsenal but cannot seem to get it to work within my theme.  I’m not sure if it’s just me, or if the theme/BoldGrid doesn’t support that particular plugin. Do you happen to know if this plugin is compatible with BoldGrid?  I’m currently using Pavilion – Real Estate theme for the site I’m building.
    Brian
    #24552
    admin
    Member
    Hello Brian,
    Thank you for your question about BoldGrid compatibility with the Popup Maker plugin.  I’m am not sure whether or not BoldGrid is compatible with the Popup Maker plugin or not, but it sounds there is a conflict somewhere.  While we try to maintain as wide a compatibility as we can, unfortunately we are not able to have 100% compatibility.
    Gratefully,
    Casey B.
  • The topic ‘Does Popup Maker Plugin Work in BoldGrid Themes?’ is closed to new replies.
