  • #22688
    I’m using the BoldGrid Grid One Theme. I’ve easily created a drop down menu that is positioned to the right of my header. But I can not create a drop down menu that is either above the header or the footer. The same method will not work for those menu locations. Any help would be appreciated. How I created the drop down menu to the right of the header was to simply drag and drop one menu item below the other and to the right.
    #22689
    Kyle
    Member
    The GridOne theme does not support dropdown menus in those menu locations, Your best bet to circumvent this would be to find a plugin that gives you custom menu widgets and assign that widget in that location or use a custom HTML widget and make your own menu.
    Best Regards,
    KyleM
  • The topic ‘Drop Down Menu will not work’ is closed to new replies.
