- December 1, 2021 at 10:45 am #45646
Earl A Sneeringer
GuestWhen I request the editing of a page, the editing page always goes to the mobile view which I then have to click on the computer icon to get it to be a full screen. This is new and I would like to set it up so that it goes back to the way it loaded previously with the computer view being the initial view. Please advise.
December 1, 2021 at 11:03 am #45658Brandon C
ParticipantHi Earl,
Our apologies for any inconvenience this might be causing you. We’ve identified the underlying cause of the problem as a bug that occurred with the rollout of our new Full Screen Editing feature in the last Post and Page Builder update.
This issue occurs when several buttons are added to the MCE controls. We’re tracking the bug in this GitHub issue.
There are a couple of ways you can troubleshoot right now. You can use a plugin like WP Rollback to revert Post and Page Builder back to the previous version, or temporarily disable some plugins that are adding buttons into MCE. Common ones are Jetpack’s “Contact Form” module, which adds a form button, and shortcode plugins.
We’ll be releasing an update to fix this as soon as possible.
- The topic ‘Edit Page Screen Auto Loads the Mobile Editor in Post and Page Builder’ is closed to new replies.
