- July 13, 2022 at 6:59 am #55196
Sixto
GuestHello
Sorry to ask so many questions or perhaps I am looking in the wrong areas. Again, after many searches on editing font blocks etc., I can’t find the answer to this question: How does one change the font in multiple blocks at one time? For example I am writing a blog post or adding a new page. The post consists of let’s say 4 paragraphs ( I can’t make more than one paragraph within one block. When i hit enter the system automatically inserts a new text block). If I need to change the font for all the paragraphs in the post (all at one time) how is this done? I thought that by clicking more than one paragraph box (text box) I could change the font size for both boxes, however, this does not seem to be the case since the “edit font” option drops out. It is super tedious to go into an entire blog post with multiple paragraphs and change the font one paragraph (one text block) at a time.
Thanks in advance,
sixto
July 13, 2022 at 7:04 am #55210Brandon C
ParticipantHi Sixto!
We certainly don’t mind your questions! I think we can help with this as well.
You can control fonts globally from your Crio Pro WordPress theme customizer.
From your WordPress dashboard navigate to Appearance < Fonts and from this dashboard you’ll have the ability to control your theme fonts globally. This setting will not effect any elements with a specific font applied to it in BoldGrid Post and Page Builder.
I hope this helps Sixto!
July 15, 2022 at 10:20 am #55230Sixto
GuestThanks Jason,
Yes i am aware of this option for fonts.
My question is the following:
I am in the Blog Post page where there are several boxes of text (each box is an individual paragraph). I can edit the font size etc for each box individually however, I have a post that has 10 different boxes (paragraphs of text), I can highlight all the boxes however when I do this the option to edit the text disappears. How can I choose multiple boxes of text and edit the font size all at once?
Sixto
July 15, 2022 at 10:37 am #55302Brandon C
ParticipantThanks Sixto,
If you’re not using a global font you would need to select each paragraph element and add the font properties individually.
You could also create a custom CSS class for your section fonts and add it under the Advanced Controls < Custom CSS Classes setting of the section containing your paragraphs.
July 20, 2022 at 7:55 am #55350Sixto
GuestThanks Jason,
Boy this was frustrating. How do I “You could also create a custom CSS class for your section fonts and add it under the Advanced Controls < Custom CSS Classes setting of the section containing your paragraphs”?
Seems so much easier to have the option to click all the paragraphs at once and just change the font as i have had to do with the last post for each individual paragraphs
Thanks in advance,
Sixto
July 20, 2022 at 8:08 am #55402Brandon C
ParticipantHey Sixto,
I definitely understand, building WordPress can be difficult at first but believe me it gets much easier as you learn more.
If you would like to take this approach we have a guide that will show you how to do just that. You will of course need a basic understanding of CSS.
Please let us know if you have any other questions Sixto!
- The topic ‘How do I control font globally in my Crio WordPress theme’ is closed to new replies.
