- July 13, 2020 at 2:52 pm #25034
Scott
GuestI read the response for using the CSS editor for turning off the first letter on the “wedge” theme. The trouble is, the tech answer falls short. Where exactly is the change needed? I can easily get into the CSS sheet, but I have no idea where the code is that defines that change. How do you find that?
July 13, 2020 at 3:07 pm #25039Jesse Owens
KeymasterHi Scott,
Rather than editing the stylesheet directly, I recommend using the Custom Theme CSS in Customize > Advanced > Custom JS & CSS.
Use this line to unset the first letter style:.site-title::first-letter { color: unset !important; }
July 13, 2020 at 4:35 pm #25046Brad Markle
KeymasterHi Scott,
I wanted to piggyback off of what Jesse shared, and create a video to show you how to make these changes in the Customizer. I hope this helps!
– BradJuly 15, 2020 at 10:48 am #25170Scott Avery
GuestThanks so much for this tip. It worked beautifully. I very much appreciate the value in your products and services as a company. Very user friendly and well designed looks.
- The topic ‘First letter in wedge’ is closed to new replies.
