  • #80854
    Leonid
    I said plugin Version 2.3.0. I don’t have an active Redis field. I can’t find where I can tell which port redis is running on. In Advanced – there is no required option. Also, some options are not available, such as Late initialization. Why ?
    #80857
    Hello Leonid,
    W3 Total Cache only recognizes if a Redis PHP extension is installed/ enabled on your server. Once installed/detected, Redis will be available to select as a caching method for caching modules.
  • The topic ‘Hello. I’m having problems with Redis.’ is closed to new replies.
