  • #21974
    Looking for a possible fix. I installed MenuMaker Pro but the side bar menu takes about 5-10 seconds to load on first visit and every time a new category is selected. Any help would be great!
    #21975
    Arnel C
    Member
    Apologies for the problem with your menus after installing MenuMaker Pro.  This is a third-party plugin that we did not create, so we cannot provide support with it.  You may want to contact their developer and ask for further assistance.  If they can identify the problem and require further assistance from BoldGrid, then we would the specifics to determine if there is anything we can do to resolve any possible software conflict.
    If you have any further questions or comments, please let us know.
    Kindest regards,
    Arnel C.
  • The topic ‘Help with CSS Menu/MenuMaker Pro’ is closed to new replies.
