  • #154381
    Christina Rená
    I recently “built” a WordPress website using Boldgrid Crio and am so happy with how it looks… on a laptop/ desktop. It looks TERRIBLE on a mobile screen. I have attempted to fix this on my own and run into highly technical solutions (with scolding from tech savvies that I shouldn’t expect to be able to do this when it takes a degree or two for web design, etc). I have compressed my media and uninstalled unnecessary plugins with no change. I am finding, of course, after all my content/ media is in, that I should have begun my design from the perspective of a mobile screen first. However, the reason I chose Crio is because it was advertised as responsive. So I naively assumed this would be automatic (wah wah). How do I get some help, on a novice level, to get my site mobile responsive as soon as possible?
    #154426
    Elana
    Hello Christina,
    Thanks for reaching out, and thanks for using Crio. I’ll try to address each of your concerns.
    The responsiveness of many website areas in our themes, like the header and footer sections, are automatically designed to shift their content to create a readable mobile display.
    Some of the things you can look at the help your site become more mobile responsive.
    1. There are also some Responsive Utilities provided by the Post and Page Builder that allow you to select the device type and change how your content looks for difference screen sizes.
    2. Inline hamburger menu on mobile – One great thing about your Crio theme is you have the ability to structure your page headers in many different ways. What you should do is open your WordPress Customizer and navigate to design < Header < Site Header Layout < Select Layout and switch your site header layout to one that better fits your needs.
    3. Font size of various headers on mobile – You can control responsive text size in your theme from the WordPress Customizer Fonts section.
    4. Container widths on mobile – You can use the responsive utilities in Post and Page Builder to adjust your content for smaller screens. These controls are very similar to the global typography controls the WordPress Customizer.
    I hope that helps you configure your content as expected and please let us know if there is anything else that we can do to help.
    Elana D.
  • The topic ‘help with mobile responsiveness for a novice’ is closed to new replies.
