- June 28, 2018 at 8:57 pm #22363
MemberI’m working in hifidel theme and on the home page is a slideshow feature. I successfully added one image but when I attempt to add more they either replace my original one or strangely appear above it. I simply want to add a few move photos to create the slideshow. Please help.
June 29, 2018 at 3:20 am #22368Arnel C
MemberHello,
Thanks for the question about the slideshow in the Hifidel theme. When you open the Home Page in the Hifidel theme, you need to click on CLASSIC EDITOR. If you initially open it, it may open up in the new Gutenberg editor. You need to click on All Pages in the Pages section, then click on Home Page and Classic Editor. Click on the top image (the slider), and then click on the pencil icon in order to see the gallery of images associated with the slider. You can then edit and change the images that are in the slider. Make sure that you are using images that have the same dimensions.
June 29, 2018 at 9:03 pm #22367lindaB
MemberArnel,
When I open all pages and in the pages section, then click on home page. I don’t see anything that says Classic Editor. I see Edit, Quick Edit Trash View. When I click on Edit it takes me to the image that I added to slider. I click on the pencil icon and it takes me to Image detail NOT the image gallery.
Thanks for responding
July 2, 2018 at 1:03 pm #22366Arnel C
Member(note: I’ve re-published this as an ANSWER so that the HTML formatting applies. I had earlier added it as a comment and it was difficult to read.)
Sorry for the continuing issue with the HiFidel theme. Can you tell us what versions you’re using for both the theme and WordPress? Here are my screenshots – I am using the latest versions of both.
Screenshot shows I’m using the Hifidel theme:
Screenshot shows the Classic editor option:
Video shows how I’m getting to the Gallery screen:
When I click on the first image of the slider, I am seeing an edit option. You can see me clicking on it in the video above. The Gutenberg editor is a new WordPress editor that is currently a plugin for WordPress. It will eventually be integrated into the WordPress interface. I currently have it loaded on my test site. You may not have it loaded, but you should still be able to see the BoldGrid edit options.
Please confirm your steps and let us know what versions you are using. You can find the theme version under Customize > Change Themes > Theme Details. My version of Hifidel is 1.24.1 and my WordPress version is 4.9.6. Also, if you could double-check the Inspirations plugin version (under Plugins). It should be 1.5.8 for the latest version. Hope that help! Please provide us a little more info and we can look into it further.
July 3, 2018 at 6:29 pm #22365Anonymous User
MemberArnel,
I’m using word press 4.9.6 and hifidel 1.24.1 both the latest. I do not have the Classic Editor option. As I said earlier my choices are EDIT QUICK EDIT
TRASH VIEW.
All 6 plugins are activated including Bold Grid Inspirations version 1.5.8.
When I click on the current photo (on hifidel home page) I don’t get just 2 choices edit and remove, I get edit, remove, change and 4 for alignment. If I click edit, it does NOT take me to edit gallery, it takes me to image details.
I built galleries and sliders on 2 other pages and on them when I click on the edit icon it does take me to edit gallery as it does in the video you sent me.
Thanks for all your help.
lindab6
July 6, 2018 at 12:20 am #22364Arnel C
MemberHello Lindab6,
Sorry for the continuing issues with the Gallery and not being able to edit it. Our determination of the issue is that there is either something not loaded properly for the BoldGrid plugin (Gallery) or there’s a conflict with another plugin. Make sure that you do have the Gallery plugin from BoldGrid. If it’s not loaded, then you can get it from the BoldGrid.com site. If you have it loaded and it is current, then try deactivating your other plugins one by one to see where there might be a conflict. Please let us know if this helps!
- The topic ‘Help with slideshow in hifidel.’ is closed to new replies.
