  • #44890
    Jesse
    My site has several pictures that I wish to change. The main one is the picture of a laptop and printer. How can I go about removing it and adding my own.
    Thank you.
    #44910
    Hi Jesse,
    Thanks for reaching out and thanks for using Crio Pro WordPress theme!
    You can add and replace images using the BoldGrid Post and Page Builder. Just navigate to Pages from your dashboard and hover over the page you need to update and click Edit. Once you have the page open in the editor click on the image you want to edit and you’ll see an options menu pop up above the image. Click on the change image icon.
    click chage button for image
    This will bring you to a new page that will allow you to update your image. Once you have your new image selected be sure to click Replace. Then Publish the page to save your changes.
    I hope this helps! Please reach back out if you have any other questions.
    • This reply was modified 3 years, 4 months ago by Brandon C.
  • The topic ‘How Can I Add and Replace Images with BoldGrid Post & Page Builder?’ is closed to new replies.
