  • #54753
    Sixto
    Done, done, done except for one thing!
    I have made links from the main menu (Holistic Wellness, for example, Learn More) which when clicked takes the client to the part of the background information page where I have placed an Anchor link #HolisticWellness. Everything works, click on the link and it takes you to the page however….. due to the Sticky Menu, the Sticky Menu covers the top part of the page (where the Anchor link is placed). So due to the sticky menu, the page directs to the Anchor LInk however, the top part of the page where the Anchor Link exists is hidden behind the sticky menu.
    I have done a workaround by placing the anchor link higher on the page. However, in order to do this, I had to push down the text blocks which leaves the page with an unsightly amount of space between the text blocks.
    How can I make the link go directly to the page’s Anchor Link (where I want it to be) instead of me having to place the Anchor LInk higher on the page in order for the STicky Menu NOT to cover the targeted area.
    #54801
    Hi Sixto,
    Thanks for reaching out with your Crio Pro WordPress theme!
    You may be able to adjust the padding of either your Sticky Menu using Crio’s advanced WordPress design controls, or your Anchor Link element inside of the page itself, in order to get them to display correctly. Could you please send us an error of the exact issue using ImgBB so that we can be sure we’re addressing the correct area for you.
    We look forward to assisting you further with this Sixto!
  • The topic ‘How can I Adjust my Crio WordPress Sticky Menu to Work with my Anchor Links?’ is closed to new replies.
