- January 11, 2023 at 1:51 pm #75799
Gary
GuestHi, I’m using BoldGrid through my host service and am using the stock audio player. The player has an icon with a music notes. I wanted to ask how I can edit that icon to be something else. Thanks
January 11, 2023 at 1:56 pm #75820Brandon C
ParticipantHi Gary,
Thanks for reaching out with your BoldGrid Post and Page Builder questions!
At this time there’s no easy way to add an icon to the native audio player without digging into code. You could possibly change it with and hook that would select the original icon and replace it with your new one but you may need to consult with your developer for that.
What I can do is suggest this feature to our dev team as a feature request and if accepted it will be implemented into Post and Page Builder in an upcoming update. Of course you can check back here at anytime for updates on the matter.
Thanks Gary!
January 12, 2023 at 10:26 am #75833Gary
GuestThanks Brandon,
I have the audio player on my home page but when I go into the code on my home page I don’t find the code for the player. I know some code. If I knew where the code for the player is I could work with it. Anyway you could point me to that place?
Gary
January 12, 2023 at 10:32 am #75931Brandon C
ParticipantThanks Gary,
I was able to inspect the page and that particular icon can actually be changed from your WordPress “Media” dashboard on a “file by file” basis.
You would need to select the audio file and update its featured image and that should be enough to change the icon.
If you would like to change it globally you would need to find and replace this file within your WordPress file structure
/wp-includes/images/media/audio.png
.I hope this helps Gary!
- The topic ‘How can I change the audio player icon in Post and Page Builder audio component?’ is closed to new replies.
