Hi Stephen,
No, you don’t need the Premium version of Post and Page Builder to adjust column widths within a block. Here’s how you can adjust column widths:
In your WordPress dashboard, go to the page or post you want to edit.
hover over the block that contains the columns you want to adjust and select the hamburger toggle from the blue column selector, then choose Advanced Control.
Here you’ll see controls for the padding and margin of your Post and Page Builder columns which will allow you to adjust the width.
