- March 28, 2017 at 1:31 am #24410
MemberUnsure what’s going on. I’ve tried four times, reinstalling WordPress each time.
My domain is on a cPanel server running on a 64 bit CentOS system with PHP 5.6.30 and MySQL 5.6.35. It is secured with an AutoSSL cPanel certificate. I’ve used both Softaculous WordPress installer, and manual installation for both WordPress and BoldGrid. I can download and install the base plugin, which then prompts be to install the editor plugin, so I do. I then run through the First Time User’s Getting Started option, and after it downloads the site and installs the additional required plugins, I am presented with the suggestion to proceed to the Customizer. At that point attempting to access ANYTHING at all in the Dashboard just gives me a blank page, as does attempting to access the front end of the site.
I found that if I deactivate the BoldGrid Ninja Forms plugin (by removing it from the plugins folder) I can then access both the Dashboard and the front end, but still not the Customizer. Deactivating ALL other BoldGrid plugins except for Inspirations still doesn’t give me access to the Customizer. I have NO other plugins active.
The site displays in the front end – https://webportfolio.space/ – but any attempt to access the Customizer just results in a blank page with the following URL in the address bar:
I’d love to take this for a spin, but I’ve already now wasted more than half a day on a site that I was hoping to have done in that time. Any feedback would be great. Thanks.
March 28, 2017 at 1:47 am #24411mrhasbean
MemberI think I’ve fixed this. I noticed another post mentioning a customiser issue that suggested increasing PHP memory limit. After increasing to 512M it seems to be working.
SUGGESTION: Have the plugin check the PHP memory limit on activation and informs the user if it should be increased…
September 21, 2020 at 10:58 am #27310Keshavamoorthy
GuestI activated ninja form and getting blank screen. Unfortunately i am not taken backup till this place. Please help me in deactivating this ninja form and make wordpress admin page accessed
Keshav
September 21, 2020 at 11:02 am #27322Jesse Owens
KeymasterHello Keshav-
If you’re not able to access your dashboard, you can deactivate a plugin with FTP or your host’s file manager using these instructions. You can also use these instructions to deactivate a plugin using the command line over SSH.
- The topic ‘How Do I Fix My Blank Dashboard?’ is closed to new replies.
