  • #77113
    David Wilson-Steer
    The published page on my Woocommerce site looks different to the page in edit. Things get squashed out of shape, pictures are different sizes. When I try to correct by altering the block or font sizes it seems to get worse. I’ve read the two posts that refer to this and I’ve tried the suggested option which is basically to save the permalink. Also, you promote BoldGrid as having a simple drag & drop system. Where can I find that? When I try dragging & dropping elements they end up in strange places. Also, your documentation is not very helpful. In fact most of it just describes what a block or column or element is but not how to use it. In fact your documentation has a basic flaw in that it uses different terms for the same thing which is bad writing. ‘Section’ and ‘block’ come to mind which apparently refer to the same thing.
    #77143
    Hi David,
    Thanks for reaching out with your BoldGrid Post and Page Builder questions!
    I’m sorry to hear you’re having a bit of trouble but I’m sure the reason for this is incompatibilities with your StoreFront theme. Post and Page builder was created to seamlessly integrate with BoldGrid Framework based themes such as Crio Pro WordPress theme.
    The Storefront theme actually functions much better with the standard WordPress block editor so I’d recommend at least switching your preferred editor for your WooCommerce product pages.
    If you’d like to try Crio Pro WordPress theme we welcome you to do so. Crio comes with over 400 customizable options out of the box and as I mentioned integrates 100% with BoldGrid Post and Page Builder.
    I hope this helps David, please let us know if there’s anything else that we can answer for you!
  • The topic ‘How do I modify a WooCommerce page with BoldGrid Post and page Builder and Storefront theme?’ is closed to new replies.
