Hi Tom,
Thanks for your question and thank you for using BoldGrid Post and Page Builder for WordPress!
Are you trying to place a background behind a footer or sidebar widget? If so you may be able to change it in the Appearance<<Customize<<Widgets section or using Custom CSS.
If you want to change background text on one of your pages it may just require changing the background color or media file for a specific section, row or column.
If you could direct us to the widget area or page URL you would like to modify we can take a look and give you our suggestion on what needs to be done.
I hope this helps. Please reach back out with your question or concerns.
- This reply was modified 3 years, 5 months ago by
Brandon C.
