  • #77279
    Rose
    Hello! I am using Bold Grid for my new site. The site is set to DO NOT INDEX even though I have not checked the box to discourage search engines, and I have looked all over for a way to fix this, to no avail. Can you please help? I’ve worked very hard to set up this site and I’m heartbroken to have run into this issue. Thank you!
    Rose
    #77344
    Hi Rose,
    Thanks for reaching out and thanks for using Crio Pro WordPress theme!
    So indexing is a built-in WordPress feature and you should be able to switch it on and off from the Settings > Reading section of your WordPress dashboard.
    You may however want to setup Google Search Console and a SEO plugin like Yoast or RankMath if you would like more control over how pages are indexed.
    I hope this helps! Please let us know if you have any other questions for us!
  • The topic ‘How do I remove “do not index” setting from my WordPress site?’ is closed to new replies.
