  • #71165
    Boris
    Hi!
    I deleted upkeep and there is no directory plugins/boldgrid but cron is still running!
    from syslog:
    Nov 29 01:25:01 ip-172-31-34-91 CRON[160013]: (www-data) CMD (php -d register_argc_argv=”1″ -qf “/var/www/html/bl
    og/htdocs/wp-content/plugins/boldgrid-backup/cron/run-jobs.php” siteurl=https://media.biofit.blog id=cb18b0ae sec
    ret=4de5b477d96f5e96c8a88ac17134ce085a4460147a12e276210bbbaf96aeb0a9 > /dev/null 2>&1)
    Nov 29 22:20:01 ip-172-31-34-91 CRON[168256]: (www-data) CMD (php -d register_argc_argv=”1″ -qf “/var/www/html/bl
    Nov 29 22:25:01 ip-172-31-34-91 CRON[168276]: (www-data) CMD (php -d register_argc_argv=”1″ -qf “/var/www/html/bl
    Boris
    #71300
    Thanks for reaching out Boris,
    I’m sorry to hear you’re having trouble removing these Total Upkeep cron jobs. Normally the uninstall process removes crons automatically, but if something like, maybe the plugin directory is deleted by mistake you can:
    Either use your web host’s cron job manager (like cPanel or a similar tool)
    or on command line with the crontab -e command.
  • The topic ‘How do I remove Total Upkeep Cron job from my system?’ is closed to new replies.
