  • #39071
    Anita
    Hi! Wonder if you could guide me with the creation of my Blog page.
    I have this blog page that gathers blog posts that will grow in quantity with time. They appear as a list by the publishing date. Internally, the posts have categories and tags. However, I would like to create on my blog page categories or sections that would compile blogs and lead to subpages with posts collected by topics.
    It is difficult to explain, so you can see the idea on this link https://www.giovannafletcher.com/blog
    Or at least a menu with pages that contain posts
    https://cupofjo.com/category/motherhood/
    Because as I can see, there is only one assigned blog posts page.
    In conclusion, how can I exhibit an organized by categories/topics content?
    Thank you for your answer.
    #39097
    Hello Anita-
    Thanks for the great question, and thanks for using the Crio WordPress supertheme.
    It looks like you’ve already discovered how to create a menu with links to the category archives in your drop-down menu underneath “blog.”
    For designing a page that’s more organized by category, I recommend creating a custom page instead of the default “posts page.” Then, you can use the BoldGrid Post List block component. Check out this short video where I demonstrate how to use the Post List:
    #40121
    Anita
    Jesse,
    Thank you very much for your video.
    It turns out that the option of adding a Post List to my block disappeared, so as all the content I had on that page.
    Where could I find that option or gain it back?
    As you can see in the link, the page is empty now. (I displayed there a list of posts of my Recommendation category). https://www.notanotherblogaboutchile.com/recommendations/
    Best regards,
    Anita
    #40199
    Hi Anita-
    The Post List component is a part of the Post and Page Builder Premium plugin, which is included with your hosting at DreamHost. If you’re missing the Post List, it’s likely that the plugin has been deactivated or deleted. You can download the plugin directly from this link if you need it, and you can download all of the premium plugins from your BoldGrid Central Account if you need them in the future.
  • The topic ‘How to Display Blog posts organized by topics?’ is closed to new replies.
