- January 3, 2018 at 10:47 am #23219
MemberI am trying to place two buttons on the same row but cannot. Would appreciate if someone could tell me how.
January 3, 2018 at 11:54 am #23222Arnel C
MemberThanks for the question about adding two buttons in a row. We need a little more information about exactly what you’re trying to do in order to help you. Please provide us details on what you’re doing so that we can try to duplicate the issue. Otherwise, you may want to check out this article on using Bootstrap to create buttons in WordPress. There also many plugins that can help you get your buttons created.
January 3, 2018 at 12:32 pm #23221Anonymous User
MemberWith boldgrid, i have a button, i want to add another button to the right of it. I am using the + add button and it keeps placing it on different rows.
January 3, 2018 at 4:03 pm #23220Arnel C
MemberAdding buttons side by side will require that you’re in a space to do that. If you have multiple columns and there’s content in the way, then you will not be able to put the buttons side by side. Can you please provide a URL or more information on the page that you’re trying to add the buttons so that we can try to duplicate the issue and explain the issue with more clarity.
You can check out this image to see that I was able to add 2 buttons in the same row:
The option may be disabled due to content on the page or the format of the grids in the area where you’re trying to add them.
- The topic ‘how to place two buttons on same row’ is closed to new replies.
